Managing Modem Firmware
Modem Firmware Update over UART
This sample can be used to load new modem firmware to your device using the bootloader only. This is useful if you do not have a programmer!
Setup
Make sure you have the VSCode plugin installed and running. Here are the instructions for each major architecture:
Get the modem firmware
Get your modem firmware of choice by nagivating to the nRF9160 Download page and scrolling to the nRF9160 SiP modem firmware section:
Download page
Download the version you’d like to use.
IMPORTANT: currently nRF9160 Feather is shipped with version 1.3.2 of the modem firmware. You cannot downgrade according to Nordic.
Build
Build the sample located in samples/mfw_update targeting circuitdojo_feather_nrf9160_ns.
Building sample complete Building sample complete
Loading
Then load to your device:
Loading Load complete
Note for older boards (pre-v5): the auto-reset after Load via Bootloader only works on v5 and later hardware. On older boards the upload finishes but the mfw_update sample does not start automatically — power-cycle the board or press RESET manually before running the Python script. Otherwise update_modem.py will time out because the sample isn’t actually running.
Running Python script
First you need to install the dependencies by running the following within samples/mfw_update/:
pip3 install -r requirements.txt
With python installed you should be able to run the corresponding update_modem.py script easily:
python3 update_modem.py mfw_nrf9160_1.3.0.zip /dev/tty.SLAB_USBtoUART 1000000
Note: update_modem.py is located in NFED under the nfed/samples/mfw_update/ path.
Baud rate: use 1000000 — that’s the rate the mfw_update sample expects. Higher rates are not supported.
Here’s what it should look like at the end of the process.
Upload complete
Confirming
You can confirm you have the version you loaded by running the AT+CGMR AT Command using at_client:
The AT host sample started
> AT+CGMR
mfw_nrf9160_1.3.0
OK
Modem Firmware Update with nrfjprog
The easiest way to update the modem firmware is using nrfjprog.
  1. Connect your board via Tag Connect cable and to an nRF9160DK or nRF53DK.
  2. Install Nordic’s Command Line Tools if you haven’t already
  3. Download the modem firmware from Nordic in the nRF9160 SiP modem firmware section.
  4. Run the following in your terminal/shell:
❯ nrfjprog --program _bin/mfw_nrf9160_1.3.2.zip --reset
[ #################### ]   0.000s | Finding image components - Finished
[ #################### ]   0.056s | Upload segments - segment 2 of 2
[ #################### ]  43.186s | Uploading modem image - segment 2 of 2
WARNING: A programming operation has been performed without --verify.
WARNING: Programming can fail without error.
Applying system reset.
Run.
Modem Firmware Update with nRF Connect for Desktop
To update, you can use nRF Connect for Desktop. It’s important to note that not all modem firmware versions are certified to work on every carrier. Check the modem firmware release notes on the nRF9160 download page for carrier certification details before upgrading.
Mac users: when downloading modem firmware, your browser may automatically extract the .zip file. If this happens, re-compress the folder using the command line (zip -r firmware.zip firmware_folder/) rather than using Finder’s “Compress” option, which can add macOS-specific artifacts that cause the update to fail. Alternatively, download the file using wget or curl to preserve the original .zip.
Another note: you will need a programmer and Tag Connect cable in order to update the modem firmware.
Here are the instructions for updating your modem firmware:
  1. Download the modem firmware you need.
  2. Next, open up the Programmer in nRF Connect For Desktop. (You may need to open it first)
  3. Then open up a connection to your programmer. (Your programmer should be connected to USB and attached to your nRF9160 Feather) Port choices
  4. Once opened, the program will read the memory contents of your device and display it. Reading non-volatile mem
  5. To update the modem firmware, scroll down to the bottom right and click Update modem Update modem button
  6. Find your modem firmware Find modem firmware
  7. Start the DFU process by clicking Write! Start the process
Then, your device will be updated. This process takes about 45 seconds. You can check if the firmware version using the AT+CGMR AT command. Devices running on Verizon must use modem firmware v1.1.2.
