Arduino/Particle
The Arduino library has been updated to work with V6! See the quickstart below.
Sample code is located here: https://github.com/circuitdojo/air-quality-wing-code
Library is located here: https://github.com/circuitdojo/air-quality-wing-library
Quick Start:
This quick start assumes you have Particle Workbench installed.
- Clone this repo onto a place on your machine:
git clone git@github.com:circuitdojo/air-quality-wing-code.git - Init the library submodule using
git submodule update --init --recursive - Open the repo with Visual Code: (
code .using the command line, orfile->open) - Open
/src/AirQualityWing.ino - Select your target device in the lower bar (Options are:
argonandboron) - Hit
cmd+shift+pto get the command menu - Select
Compile application (local). You can also chooseCloud flashas long asboard.hhas not been modified. - Enjoy playing around with your Air Quality Wing!
This example has been tested with DeviceOS 3.1.0. It’s recommended to upgrade if you have problems.
