Example Code
Examples
All examples can be found in the nRF9160 Feather Examples and Drivers (nFED) repository. You can install it during the setup process. Here are some links to setting up on different platforms:
All samples are in nfed/samples (or nfed/samples depending on how you set
everything up). They include:
- accelerometer - for a basic onboard accelerometer demo
- at_client - for testing connections using LTE Link Monitor (📶 requires SIM if you want to connect to LTE/NB IoT)
- battery - for a basic onboard battery measurement demo
- blinky - for a basic led blink demo
- bme280 - for an example of using the bme280 on i2c
- button - for a basic example using the onboard mode button
- deep_sleep - ultra deep sleep mode demo
- external_flash - external flash demo
- external_rtc - using onboard RTC demo
- gps - basic gps demo (📶 requires SIM if you want to connect to LTE/NB IoT to retrieve SUPL data). See SUPL assistance below for faster fixes.
- sms - basic SMS demo (📶 requires SIM to send SMS). See Sending SMS below for AT command reference.
Most of these examples are based from the nRF Connect SDK (either directly from Nordic or Zephyr)
SUPL GPS Assistance
SUPL (Secure User-Plane Location) dramatically speeds up GPS time-to-first-fix by downloading almanac and ephemeris data over LTE instead of receiving it from satellites directly. To enable it in the gps sample:
CONFIG_GNSS_SAMPLE_ASSISTANCE_SUPL=y
CONFIG_GNSS_SAMPLE_SUPL_HOSTNAME="supl.google.com"
You’ll also need to configure the antenna correctly for the nRF9151 Feather’s AUX antenna pin:
CONFIG_MODEM_ANTENNA=y
CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586"
Note: The SUPL client library requires a separate license agreement and download from Nordic’s website. Search for “SUPL client library” on the nRF9160 downloads page.
Sending SMS
The sms sample uses AT commands to send messages. To send an SMS in text mode manually using the at_client sample:
AT+CMGF=1 # Set text mode
AT+CMGS="+1XXXXXXXXXX" # Recipient number (international format)
> Your message here<Ctrl+Z> # Type message, send with Ctrl+Z (0x1A)
The modem responds with +CMGS: <mr> and OK on success, where <mr> is the message reference number.
Building and loading using VSCode
Using the command window run Zephyr Tools: Build
Then place the device into bootloader mode:
- Hold the MODE button
- Then tap the RST button while holding mode
- Hold the MODE button until the Blue LED illuminates
Then, load using the Zephyr Tools: Load via Bootloader task.
Pay attention to the progress in the bottom console.
Once complete, the extension will reset your device and should start executing!
Note for older boards (pre-v5): the auto-reset after
Load via Bootloaderonly works on v5 and later hardware (with the buttonless DFU/RESET routing). On older boards the upload finishes but the new firmware does not start automatically — you have to power-cycle the board or press RESET manually to boot into the new image. If you connect to the serial console and see no output after a successful upload, that’s why.
Important: make sure you close all console sessions with your nRF9160
Feather before programming using newtmgr. Otherwise the newtmgr image upload
will timeout.
Building Manually
To build an example,
- Install and setup the VSCode Extension for your OS:
- With the extension installed and setup, navigate to the sample you want in a VSCode terminal and run:
west build -b circuitdojo_feather_nrf9160_ns
Here’s an example of output when finished:
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/jaredwolff/Git/nrf-connect/ncs/nrf/samples/nrf9160/at_client/build
[0/180] Performing build step for 'spm_subimage'
[151/155] Linking C executable zephyr/zephyr_prebuilt.elf
FLASH: 32256 B 48 KB 65.62%
SRAM: 5488 B 64 KB 8.37%
IDT_LIST: 40 B 2 KB 1.95%
[155/155] Linking C executable zephyr/zephyr.elf
[2/176] Performing build step for 'mcuboot_subimage'
[248/253] Linking C executable zephyr/zephyr_prebuilt.elf
FLASH: 42500 B 48 KB 86.47%
SRAM: 26800 B 64 KB 40.89%
IDT_LIST: 72 B 2 KB 3.52%
[253/253] Linking C executable zephyr/zephyr.elf
[163/176] Linking C executable zephyr/zephyr_prebuilt.elf
FLASH: 76868 B 441856 B 17.40%
SRAM: 36928 B 128 KB 28.17%
IDT_LIST: 120 B 2 KB 5.86%
[174/174] Generating zephyr/merged.hex
Note: having trouble building? Make sure you check out the troubleshooting page.
Programming can be completed with newtmgr:
newtmgr -c serial image upload build/zephyr/app_update.bin
Note you always want to use the app_update.bin when using newtmgr. These
binaries are also used for FOTA and are always located in
your_sample/build/zephyr/.
During testing, it’s recomended to use the LTE Link Monitor whenever you need to manually test or execute commands.
