Zephyr Examples
The Air Quality Wing has first class support on Zephyr. It can be used with almost any board that is supported by Zephyr.
Sample descriptions
The code is a a work in progress but includes a BLE example, nRF9160 Feather example an standalone sample.
Basic
The Basic example connects to and obtain samples on a regular basis. They’re printed out to the console.
BLE (Bluetooth Low Energy)
The BLE example does the same as the Basic but also connectable via Bluetooth. Once connected characteristics can be subscribed to and updated by the device.
Golioth
The Golioth example is the same as Basic but it also publishes to the Golioth IoT backend for integration with tools like Grafana.
Setting up your environment
Here is the minimal amount of steps to get an example working. This example is currently only configured for the nRF52 DK.
Hardware
If you do not have a PM2.5 sensor you can comment out &hpma_sensor, within sensors[] in main.c before building.
Virtual Environment
One of the main dependencies for Zephyr is Python. Instead of installing the required packages directly to your system, I highly recommend use a virtual environment instead.
First lets make a project folder. We can call it aqw:
mkdir -p aqw
If you don’t have virtualenv installed already, make sure you install it:
pip3 install virtualenv
Set up a python virtual environment:
virtualenv -p python3 env
Then enable it by running:
source env/bin/activate
Install west
west is the command line utility for Zephyr. You’ll need it to build the firmware.
pip3 install west
Init and update project
Next we’ll download the source code and install the dependencies.
west init -m https://github.com/circuitdojo/air-quality-wing-zephyr-demo.git --manifest-rev main
Or already cloned locally:
west init -l .
Then run
west update
This will download all the dependencies. If there are ever fixes to this sample you’ll need to pull the changes and then re-run west update:
git pull && west update
Install remaining python dependencies
Finally, there are some important dependencies needed to build your freshly cloned Zephyr repository. Let’s install those here.
pip3 install -r zephyr/scripts/requirements.txt
Install toolchain
For Mac run the following: (it does require you install
wget.brewis an easy way to do so:brew install wget)cd ~ wget "https://developer.arm.com/-/media/Files/downloads/gnu-rm/9-2019q4/gcc-arm-none-eabi-9-2019-q4-major-mac.tar.bz2" tar xvfj gcc-arm-none-eabi-9-2019-q4-major-mac.tar.bz2 rm gcc-arm-none-eabi-9-2019-q4-major-mac.tar.bz2Note for Catalina users you will get an error when running these utilities for the first time. You must allow them to be executed in your Security preferences.
For Windows you can download and install the toolchain with this direct link.
Golioth
You will need to edit golioth.conf with your credentials in order to connect to Golioth’s backend. More instructions on setting up your credentials can be found here. You can also create devices and add credentials within the Golioth Console.
Building
nRF52840 DK
cd demo
west build -b nrf52840dk_nrf52840
Then flash using
nrfjprog --program build/merged.hex --chiperase --reset
or load via the bootloader
newtmgr -c serial image upload build/zephyr/app_update.bin && newtmgr -c serial reset
Xenon
cd basic
west build -b particle_xenon
Then flash using
nRF9160 Feather
cd basic
west build -b circuitdojo_feather_nrf9160_ns
Then flash using
