Updating modem firmware
You can update the modem firmware on the nRF9151 Feather using the updater CLI. It’s cross platform and can be easily installed following the steps below:
1. Install the Rust toolchain
Install Rust using rustup.
On macOS and Linux:
curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
On Windows download and run the installer from rustup.rs, then open a new PowerShell or Command Prompt window.
After installation, confirm the toolchain is available:
rustc --version
cargo --version
2. Install with cargo
cargo install --git https://github.com/circuitdojo/modem_updater.git
This places the updater binary in ~/.cargo/bin (or the equivalent on Windows).
3. Install probe dependencies
Sometimes you may need to install dependencies. If your compilation fails here are some suggestions:
- Linux: ensure
libusb-1.0is present (sudo apt install libusb-1.0-0). - macOS: install Homebrew and run
brew install libusbif it is not already available. - Windows: if necessary, use Zadig to install a WinUSB driver for your debug probe.
CLI Usage
To program and verify the modem firmware, run:
updater program <path_to_firmware_zip>
To verify the modem firmware version running vs the provided .zip, run:
updater verify <path_to_firmware_zip>
